98 civic lx door locks won't work
Old Feb 25, 2008 | 03:09 PM
Default RE: 98 civic lx door locks won't work
Sorry for the misspelling -- I meant to write "improvising" as opposed to "improving."
Old Mar 14, 2018 | 04:44 AM
i-mod's Avatar
I had this same issue and took days to figure out that the wires were broken off at the plug that goes into the door from the car. Over time I guess the wire get brittle and snap off at the pins. Pull back the rubber boot and unplug the harness from the door and inspect the wires as they go into the pins in the plug. I had to solder the wires back to the pins one by one and everything worked fine after that. I found it easier to pull off the driver side fender to give me easy access to the harness and used brake clean to clean off the grease from the harness (make sure when done to put new dielectric grease back on). I had 3 wires that had broken off and ended up fixing them all to be safe. Was a pain in the *** but it did the job. My brother has the same issue on his Civic a few months later so I guess it's a common issue.
kabinski
Sep 2, 2009 05:24 PM
kjla0504
Jul 28, 2008 08:58 AM
SI_smiley07
Aug 8, 2007 08:53 AM
mikeym
May 31, 2006 09:09 AM
lilol89crx
Jul 29, 2004 06:56 PM
