98 civic/no spark
Old Jun 12, 2010 | 01:59 PM
lambo's Avatar
Default 98 civic/no spark
Hi.
I have a 98’ civic EX-1.6VTEC, the first symptom was the dash board lights very dim and then it gradually come on after 10-20 minutes of driving. After that the car starts intermittently, it runs good once it’s start. The other day it was really hard to start but it did then it just went dead. I checked for the spark but was nothing. I replaced the ignition coil still nothing. ..need help!!!
Old Jun 12, 2010 | 02:16 PM
redyute's Avatar
You probably need to replace the igniter too its inside the distributor as well,you should check to see if it has a crank sensor code then you might as well get a new distributor
Old Jun 12, 2010 | 02:24 PM
lambo's Avatar
Please elaborate!
Old Jun 12, 2010 | 02:43 PM
tonyhatchetman's Avatar
Originally Posted by lambo
Please elaborate!
he means that it would be cheaper to buy a new dizzy than try and re build that one ..........do you have any cel s ?? He's saying that it could be the crank sensor .........
I belive that is right some one correct me if I'm wrong
Old Jun 12, 2010 | 03:06 PM
lambo's Avatar
Thanks. I wasn’t sure what he meant by “check to see if it has a crank sensor code”.
What is “cel s”?
Old Jun 12, 2010 | 03:28 PM
What is “cel s”?
check engine light
Old Jun 12, 2010 | 04:01 PM
lambo's Avatar
check engine light
o..
Thank you all. I will keep you posted.
Old Jun 12, 2010 | 04:26 PM
Igniter would not affect dashboard lights. Problem sounds like it's in the charging system... either the alternator or battery. Since it would start sometimes and keep running, I think it is your battery... what sounds like it is happening is that the battery barely had enough charge to start the car and once it would start, the alternator kept it running. Now your battery has stopped working completely and you can't even start the car at all.
Have the battery tested at the auto parts store (it's free) and buy a new one if it fails the test.
Old Jun 12, 2010 | 07:38 PM
lambo's Avatar
Thanks for your response. I replaced the igniter it was bad (tested by Autozone). Everything went well so far including the dashboard lights, I'll keep it in mind if the dashboard lights acting up again.
Thanks everyone.
Old Jun 12, 2010 | 07:39 PM
Very strange dashboard light situation then. odd
wongthao
Nov 17, 2006 05:22 AM
boostnub
Oct 25, 2006 05:59 PM
rok_spitfighter
Oct 18, 2006 02:05 PM
onetrackmind
15
Aug 18, 2005 08:06 AM
jnash
May 17, 2005 12:19 PM
