98 civic not starting after sitting
Old Jul 6, 2011 | 07:57 PM
jlh868's Avatar
Default 98 civic not starting after sitting
My 98 civic has been sitting for 3 months (I bought a 2011 to replace it!). I was jumping it to take it to a friends garage for another problem (see my previous post), so that I can sell it. It was having trouble turning over and when it finally did, smoke came from what I think is the a/c compressor belt.
Could something have seized from sitting? What steps should I take to figure out how I can get this car to drive at least an hour away? Can I just cut the belt to free it from the engine... I'm just hoping it's not the alternator.
Thanks for your help.
Old Jul 10, 2011 | 11:42 AM
jlh868's Avatar
Well it's the alternator. Is it common for it to freeze up from sitting for too long? Or should I just replace it?
Old Jul 10, 2011 | 12:03 PM
jlh868's Avatar
Also, if the alternator was on it's way out, could it have been causing my low idle rpm's? Which then would cause the car to stall. It would only run without stalling with the ac on (cause of the higher idle).
Old Jul 10, 2011 | 12:13 PM
chromejunkie's Avatar
low voltage will cause it not to run with out a full charge the ecm will not send the right signal to the motor for fuel and spark
Old Jul 10, 2011 | 02:39 PM
jlh868's Avatar
i fully charged the battery. all belts are moving, the alternator pulley is not moving...hence the burning rubber. the engine tries to turn over and shakes when trying to start it.
so are you saying the alt isn't turning because of the possible lack of charge from the battery?
i have a friend with tools and some experience on honda engines who is willing to help, i just need to know the steps to take to diagnose this problem and/or replace the alt
Step 1: test the battery
Step 2: test the voltage on the alt?
i am going to check out my ignition switch too, since it may have been the (unresolved) cause of the car stalling to begin with...and the IACV while i'm at it.
Thanks
Old Jul 10, 2011 | 02:48 PM
Remove alternator belt, then try to start. Quite possibly it's simply that the drag is not allowing the engine to spin fast enough to get started.
It may be possible to free the alternator by turning it with a wrench. The tolerances inside are quite tight and a little rust will bind the rotor to the stator. Or you can take it apart and clean the rust off.
Old Jul 10, 2011 | 05:28 PM
jlh868's Avatar
Thanks. I think it's the drag too. Will try to free the alternator, it's really corroded.
Old Jul 11, 2011 | 06:56 AM
remove the belt from the alternator and try to start it if it runs fine with a full charge on the battery then the cause will be the alt. you also can take it to autozone or advanced auto and they can check it for you
Old Jul 17, 2011 | 06:42 AM
jlh868's Avatar
Removed the belt, engine started right up. Rpm's started soaring, had to adjust the throttle. Not sure why that happened, maybe from cranking the engine repeatedly? It's on a flatbed, so I can get it to my friend's garage and replace the alternator.
Any thoughts on using rebuilt alternators?
Old Jul 18, 2011 | 10:11 AM
if you have a local shop to do it they test them pretty good should have no issues
97Ej8
Mar 25, 2012 01:50 PM
red98ex
15
Oct 4, 2011 05:35 AM
boets
Sep 17, 2010 10:22 AM
svannasmilz
Mar 6, 2008 12:26 PM
Jeremy102579
Dec 11, 2007 10:07 AM
