98 ex rear tires toe in? out?
Old Jul 1, 2010 | 05:44 PM
tonyhatchetman's Avatar
Default 98 ex rear tires toe in? out?
hi my rear tires are at an angle at the top to the inside like this / \ and the back sits a bit lower than the front but the car has not been lowered what could be the problem ? springs ? struts ? or both i did put 2 washers on each of the upper control arms it did help with the angle some but not enough
could i add more washers with longer bolts ? what size is the bolt ? if so so i can get longer ones.
but i still would like it to be raised back up in the back if possible
thanks for any insight
Old Jul 1, 2010 | 07:33 PM
NonRicer's Avatar
Mine were like that. This way is camber../ \ You have to have a rear camber kit to adjust that. There isnt any other way that I know of. Someone else might be able to correct me if im wrong. As far as sitting lower...struts might be shot?
Old Jul 2, 2010 | 02:27 AM
So if the struts/springs or both are worn would that make the camber be out? It all looks stock and I just replaced the upper control arms so I'm wondering if that could be the problem .
MaximusFunk
May 17, 2013 08:26 AM
dkyer420
Dec 20, 2011 06:38 AM
kdubbla
Aug 6, 2009 04:23 PM
addiction2bass
14
May 25, 2007 06:57 PM
addiction2bass
May 11, 2007 11:58 AM
