99 civic ac belt rwplacement
Old Jul 25, 2005 | 08:37 PM
louied's Avatar
Default 99 civic ac belt rwplacement
looking for info on replaceing the ac belt?
It looks easy , remove the PWR Steering belt and it looks like a tensioner on the ac belt needs to be compressed> thats where im lost and need more info .
I dont own a chiltons on it .
Old Jul 25, 2005 | 09:04 PM
sacicons's Avatar
Default RE: 99 civic ac belt rwplacement
20 bucks for a chiltons or Haynes will be the best money you ever spend on your car. if you want to start doing your own wrenching, you know you will eventually buy one, so just get it over with.
Old Jul 26, 2005 | 07:41 PM
noops's Avatar
You have to remove the engine mount thats in the way of getting the belt out
Old Jul 26, 2005 | 08:58 PM
sacicons's Avatar
yeah, but you only have to remove the part that is mounted to the car, not the part attached to the motor.
Old Jul 27, 2005 | 04:14 PM
louied's Avatar
thanks for all the info , is was no problem, the whole reason i changed the belts cus they wer squelling, and this morning the squeel was gon since i did the belts last night, and after work to day i started driving and the squeel came back? maybe just an adjustment or the compresser is in need of some oil? using the AC ofcourse
any thoughts?
Old Jul 27, 2005 | 06:53 PM
sacicons's Avatar
adjust it a little tighter. does it do it for a couple seconds when you first start it, or does it do it when you rev it high?
Old Jul 27, 2005 | 08:35 PM
louied's Avatar
seems to be while driving, and when i shut off the ac squeel goes away . . so i know it lies in the ac system.
Old Jul 28, 2005 | 11:42 PM
sacicons's Avatar
its possible that the clutch (ac clutch, not the one for your trans.) is going. mine does that if i rev over about 5500 rpm, but its only that high because i had a friend who worked in a shop lower the pressure in the ac system so i could rev it high enough to get on the freeway. but chances are that you just need to tighten the belt a little more.
Old Jul 29, 2005 | 07:27 AM
louied's Avatar
thanks for the tip , i did sung it up a turn or 2 on the tensioner,
But......
the squeel is comming from the blower inside the car pass side, so i guess the fan is in need of greese or something, ill have to take it a part on sunday to check it out any one ever do this?
Kyle700
Sep 18, 2014 07:44 PM
marcpasek
Oct 16, 2010 09:49 PM
pippo
Jan 26, 2010 02:40 PM
thakid
Jan 30, 2006 08:29 PM
JALTAM901
Nov 14, 2004 11:17 AM
