99 civic dx tranny
it's a automatic,133,000 miles. It was running fine. Stopped at a light and it was like it went into neutral.
I could turn it off, start it back up and put it back into gear and it would go for a few minutes. Any clues? What needs to be done?
The fluid seemed ok- towards the lower mark on the stick, but still over it.
there is no lights on the dash... I don't think the d4 light was blinking.
Does that sound about right? I'm in Dallas Tx.
When you just drain the ATF, a substantial fraction of old ATF remains in the transmission. As I understand it, a flush involves the use of a machine that removes nearly all of the old ATF prior to refilling with new fluid. Alternatively, they may drain and refill several times to accomplish the same goal.
Just don't know how hard to swap em out would be. Or if it would be worth it.
You might want to post these and additional questions in the Transmission & Differential subsection.
