99 Civic engine ticking noise
Old Mar 24, 2009 | 04:25 PM
Originally Posted by blinduvula
That actually doesn't look too difficult at all.
Do you have any other suggestions on how to spot a blown gasket or cracked manifold other than seafoam? I am just looking for a backup plan
Header gasket not head gasket. A blown head gasket would be far more serious.
The header gasket lies between the header and head. Look for smoke there. Crawl under the front end and look for smoke all along the length of the exhaust system, particularly near the engine.
Prior to doing the smoke test, check for cracks or holes in the header, cat, and exhaust pipes.
Old Mar 25, 2009 | 11:01 AM
lthao61's Avatar
he's the local auto parts guy, not a mechanic
get the vehicle diagnosed by the right people for the right diagnosis.
Old Mar 25, 2009 | 06:15 PM
gwl's Avatar
gwl
When I had the a cracked manifold, I could smell exhaust fumes in the engine compartment. It easy to spot a cracked manifold, just remove the heat shield near the cylinder head.
Old Mar 26, 2009 | 03:09 AM
blinduvula's Avatar
You are talking about a cracked EXHAUST manifold right? because I can smell exhaust fumes... This is not going to hurt anything by driving is it?
I had an appointment at a shop thoday but I think I am going to cancel... for some reason I feel they are trying to rip me off. When I went in and the guy listened to it his comments were "hopefully the bolts don't break and it won't be too expensive for you". That just kind of threw up a red flag
Old Mar 26, 2009 | 05:51 AM
Exhaust leaks are usually readily found by having an assistant stop up the tailpipe with a rag and hold it in place while the engine idles. With the outlet blocked, pressure in the exhaust system will increase to the point where you can hear, see, and feel exhaust hissing out of any leaks.
Old Mar 26, 2009 | 07:15 AM
An exhaust leak in the header would generally cause the engine to run rich (low gas mileage), and may also destroy the cat ($$$).
sidhorn
Dec 17, 2014 04:54 PM
lmissry
Mar 30, 2010 05:06 PM
96Cex
Jan 19, 2010 07:50 PM
mctwists
Jun 20, 2007 04:01 AM
vbcamry
Sep 16, 2006 07:54 AM
