99 civic missfire
Old May 17, 2010 | 06:05 AM
stilldrivin's Avatar
Default 99 civic missfire
I have 1999 civic with 175k miles and have been having evap and missfire codes appearing. From these codes what should I replace? I took it to a shop and they said everything is good?Car is running rough shudders when idleing while sitting at a light almost like its going to die.
Car
Old May 17, 2010 | 06:15 AM
Melvinsaniac's Avatar
After the car warms up, and come to a stop at a light does the car idle bad?
If so, Clean the IACV.
Old May 17, 2010 | 06:54 AM
tonyhatchetman's Avatar
have you changed the plugs , wires , cap , and rotor latley ?
Old May 17, 2010 | 08:22 AM
Default re
I haven't changed the plugs in a while and have been thinking about doing the wires and plugs. Would I need to change the coil/coils as well? No I haven't done anything to the rotor.
Old May 17, 2010 | 08:29 AM
start with the plugs wires dis cap and rotor botton ,.. And then see if that works if not might be the ignition coil , but I don't know if you can change it without changing the whole distributor .. Do that n let us know
Old May 17, 2010 | 09:02 AM
Default re
Alright I will be the wires+plugs replaced that will be no problem. Are you saying I need to replace the full distributor cap?
Also rotor button??? Location?? Difficulty installing?
Old May 17, 2010 | 09:58 AM
yes the dis/cap is the cap the plug wires go into ,it should have 3 screws and behind it is the rotor button ,loosen the screw and it will slide off the shaft ,- think it will only go one way but can't remember it might go two ways just make sure you put the new one the smae way the old one was.
Old May 20, 2010 | 05:46 AM
Default new problems
After replacing wires+plugs+rotor+distributor cap haven't had a check engine light with any codes of miss fires. Thank you. However, now I am pulling two codes P0132, P1457. Aftermarket parts are 2.25 magnaflow exhaust, KN short ram air filter. I believe its a high circuit code showing that things are running rich. What should I replace with this? Is it the O2 sensor? I have had evap problems for the last 2 years.
stefancivic04
Apr 21, 2009 04:50 AM
waineshonda
Feb 7, 2009 03:13 PM
melito25
Sep 16, 2007 08:11 AM
khizza
Dec 14, 2006 11:35 AM
KoZtaTT
Apr 28, 2005 12:19 AM
