99 civic w/engine light on, sputtering, acceleration is cutting out when driving
Old Jan 30, 2012 | 08:51 PM
civic604's Avatar
Question 99 civic w/engine light on, sputtering, acceleration is cutting out when driving
Hey my engine light came on a few days ago. I haven't yet read the codes.
The primary problem that started when the light came on was that while driving, the gas would literally stop as if I had the clutch in or as if it was in neutral. The only ways I can fix it when it keeps doing this is too either shift gears, press the gas pedal down to the floor until the gas re-engages, or lightly let up on the gas pedal and the re-press it. The car is still drivable but this could get a lot worse if I don't take care of it. It's happening almost every time I drive it but it does it inconsistently. Sometimes I can drive it for 15-30 minutes with no problems. The other problem that started at the same time is that the engine is almost kind of sputtering when idling.
Any advice appreciated.
Thanks.
Old Jan 31, 2012 | 05:54 PM
acuratech's Avatar
well step 1 is having this scanned to see which code is stored.
Old Mar 2, 2025 | 11:26 AM
damianj's Avatar
hey man im having the same issue i changed my fuel pump fuel filter coils and distributor is fine im still not sure what it is i do have a cat code on it im wondering if i have a bad header but was just wondering if you fixed your issue at all and maybe could head with mine
ganymede425
Apr 9, 2024 03:34 AM
butor
Mar 20, 2014 12:11 PM
bakuryu06
Sep 18, 2010 09:21 AM
izotop
Nov 15, 2009 02:00 PM
jbarham
17
May 11, 2006 12:24 AM
