99 Honda Civic LX - oxygen sensors
Old Jan 12, 2010 | 11:53 AM
tgifford5's Avatar
Default 99 Honda Civic LX - oxygen sensors
How tough is it to change out the oxygen sensors on the said above Civic? This is on a friends civic and thought I would help out if I can.
Old Jan 12, 2010 | 11:58 AM
It's not difficult if you buy an O2 sensor socket and have a breaker bar. Soak the old sensor in PB Blaster for awhile before attempting to remove.
Old Jan 12, 2010 | 04:43 PM
tgifford5's Avatar
How are they different? The sockets I mean. And aren't there two O2 sensors. That's what the auto parts man said.
Old Jan 12, 2010 | 04:54 PM
The socket is special in that it can accommodate the O2 sensor wires. The socket works for both sensors. But do you need to replace both?
Old Jan 12, 2010 | 05:11 PM
^The 02 sensor socket has a channel on the side of one of the edges. Can look like so:
If you have both sensor codes, there may be a problem with the wiring where the sensors are not getting power.
After you're sure a sensor is bad you can break off the part with the wires and unscrew the base part with a regular socket. Put the new one in with an end wrench, it doesn't have to be super tight.
Old Jan 13, 2010 | 06:12 AM
tgifford5's Avatar
I don't know if both are bad. A friend said the auto shop said a O2 sensor was bad. I called Advanced Auto and they asked which one. Upstream or downstream from the cat convertor. Where can one purchase that special socket? Cost?
Old Jan 13, 2010 | 07:37 AM
I think they are in Autozone's loan a tool program where you basically buy it but you are invited to return it and get all your money back after you're done. Advance might have a similar program.
Also you can take the car to Advance or Autozone or most consumer parts chains and they will read the codes for you to know which sensor.
Old Jan 13, 2010 | 08:39 AM
tgifford5's Avatar
Thanks I will suggest that if the shop did not say which one.
runswit2guns
Jul 22, 2011 09:02 AM
STREETFIGHTER50
May 21, 2011 05:27 AM
STREETFIGHTER50
Apr 28, 2008 07:58 AM
phrankie.v
Jan 10, 2008 12:51 PM
kopsickk
Jul 10, 2007 03:09 PM
