Old Apr 17, 2011 | 02:06 PM
cadaece4242's Avatar
well i think i know what it is. where do i find the in line fuse for the alternator, where do i get the fuse from can i get the whole new wire with the fuse what kinda of fuse is it
Old Apr 17, 2011 | 02:54 PM
There are no fusible links or in-line fuses in the Civic. There are big main fuses in the box next to the battery. They are special fuses that attach with screws and are not common in parts stores. You probably need to buy them from a dealer or take them out of a parts car. The main white wire from the alternator goes into the fuse box, through one of the fuses, and then out to the battery through another large white wire.
Old Apr 17, 2011 | 03:37 PM
so which fuse is it? the battery one? what is the amp of the fuse and what is it under? thank you
Old Apr 17, 2011 | 04:26 PM
my friend said that he think the alternator is going to ground, i took my alternator up to auto zone and it passed but would it still be a short in the alternator that the tester didnt see
Old Apr 18, 2011 | 07:44 AM
Do you own a voltmeter? If not, get one and there are some tests you can do. Don't take on electrical problems without one. The first test would be to see if it's really a charging problem in the first place by measuring battery voltage with the engine running.
I think the fuse between the alternator and battery is called "battery" but you can just look at all the big fuses and see if the links are intact. The big output wire from the alternator is connected to the battery all the time. If you try to R&R the alternator without disconnecting the battery, it's very likely the wire will get shorted to ground and blow the fuse.
Old Apr 19, 2011 | 09:13 AM
how do you tell if the fuse is blown it looks fine but i dont really know, if that fuse was gone why would the alternator still charges it just seems like its still drawing juice from it some how
