AC blowing hot, any advice.
Old Jun 20, 2009 | 05:26 PM
  #21
Originally Posted by kanarrjl
sure but most people don't know how do do that so that's why i suggested it, but i'd suggest to take it to a mechanic to diagnose it then if you could fix it go for it if not let the mechanic do it
In my opinion, there's not much point in posting in this forum if you are just going to take your car to a mechanic. Therefore, I always assume that the thread-maker may want to try to do the work himself/herself. In addition, it's not rocket science hooking up manifold gauges and reading the pressures, and I already posted the normal pressure readings. If the car is taken to a good mechanic, this is what he will do. You'll just pay a hell of lot more to get the readings. And you won't have learned anything from the process. You'll just have a lighter wallet. My 2 cents.
Old Jun 20, 2009 | 05:38 PM
  #22
kanarrjl's Avatar
id say going out and buying the pressure gauges would cost more than me taking it to a mechanic but that may be because my mechanic would charge me a max of $10 to do it for me thats why i posted as i did
Old Jun 20, 2009 | 05:56 PM
  #23
I seriously doubt that you could get a trustworthy A/C diagnosis for $10. You can barely buy a good hamburger for $10. If you paid $10 for a diagnosis, I think you should be wary about the advice you'd get. My guess is that the price of a basic, yet adequate, manifold gauge set would be about equal to any diagnosis from a good mechanic. The difference is that you would also own a new nice tool if you took my advice. And you would gain a new skill that you didn't have before. In the long run, you're much better off this way.
Old Jun 21, 2009 | 06:57 PM
  #24
spikeville's Avatar
Default AC blowing hot any advice
unplug the coolant temp sensor at the thermostat box fan should turn on, this will tell you if the computer can see it. Do you have any codes?
Old Jun 21, 2009 | 10:32 PM
  #25
gwl's Avatar
gwl
One other thing you can check, make sure that the temperature slide switch is working properly. I had the same problem with my Accord. The heater was on so you couldn't feel any cold air.
You can rent tools for free around my area. Autozone, Pep Boys, Kragens, ..... If you want to save some money.
aztecaa
Nov 4, 2013 10:53 AM
jenkent527
May 1, 2013 02:44 PM
sstimothy
Jun 22, 2012 06:57 AM
ncamo
Jun 5, 2012 05:57 AM
mill$civic
Sep 22, 2006 10:33 PM
