Ac /compressor in Honda Civic problems
Hi. I have an 03 Honda Civic Ex I had overheating problems and I found out that the cooling fan on passenger side didn’t work which caused the car to not start since engine was too hot. So I did some YouTubing and then i took the connector from the Condenser fan and connected to the cooling and it worked. Then I went to fuse box and found that there was no relay for the cooling fan, just a grounding wire. so I took the relay from the horn when engine was off and put it in the cooling fan relay. And now the climate control won’t light up and the fans arent working nor the ac compressor. Any solution?
Anthony Garcia
Jul 1, 2014 06:48 AM
