Adding passenger side mirror...please help!
Old Mar 6, 2006 | 02:15 AM
derblott's Avatar
Default Adding passenger side mirror...please help!
I just bought a 1992 Civic 4-door DX, and it lacks a pasenger side mirror. Is it possible to add one? I guess my main concern is how do I get that triangular trim piece off that is in the spot where the mirror goes. And do the manual-adjusting mirrors come with an inner piece w/ a hole in it for the little adjuster stick? And lastly, where is a good place to buy these things online?
Thanks a lot.
Old Sep 2, 2008 | 11:03 PM
jbum's Avatar
Thanks a lot.
Bumping this "back from the dead" thread. I have the same inquiry. My '93 DX Sedan has no passenger side mirror. Is it possible to install one?
Old Sep 3, 2008 | 07:57 AM
Does it have a mirror delete plate? Just a smooth plastic cover were a mirror should be?
The inner piece pops right off. Just pull. I'm not sure how the outer piece would be attached. Likely a VERY simple thing to take off. I'd recommend just picking up a mirror and inner piece from a salvage yard. Should bolt right on. Be sure to get the three nuts for the mirror when you hit up the salvage yard.
Old Sep 3, 2008 | 08:00 AM
Yes if you get the mirror off of a '95 (which came with a right side mirror) it will bolt right on to a '92 or '93.
Old Sep 3, 2008 | 11:03 AM
i think all 92-95 mirrors will fit just be sure its a manual mirror and you get all the pieces for it.
Old Sep 3, 2008 | 12:46 PM
jbum's Avatar
Awesome! Thanks guys. It currently has a smooth cover both outside and inside where the mirror should be. Hopefully I can find some 92-95 civics in the junk yard where I live (south bay area, san jose).
Old Sep 3, 2008 | 01:19 PM
just keep your parts.... those RICE WEIGHT REMOVAL PEOPLE WILL PAY GOOD MONEY FOR THE SMOOTHIES
Old Sep 3, 2008 | 01:22 PM
Besides when going as fast as they think they are, there's no way someone will be sneaking up behind them. So fie on mirrors!
Old Sep 4, 2008 | 09:58 AM
c3o5nnect's Avatar
Should be some clips you can pop out on the panels for the mirrors, then oem should bolt up from there.
civicrevolution
Apr 3, 2011 04:27 PM
joectx
Jul 26, 2010 06:16 PM
Mr. Chainsaw
Apr 2, 2008 06:38 PM
johnboy
Jan 22, 2007 05:21 PM
mcmichael13
Nov 29, 2006 06:08 PM
