antenna reception
Old May 12, 2011 | 07:17 AM
hobbsy3005's Avatar
Default antenna reception
is there any way to boost your antenna reception? it get blocked by houses, trees, and small buildings all the time. would buying a new one make it better? or maybe some trick to get more power to it?
Old May 12, 2011 | 10:00 AM
Is the antenna all the way out? Also look under the dash and make sure that the antenna cable is actually plugged into the radio.
If your car has the pull-out antenna by the door it is not expensive to replace but reception problems are often with the radio.
Old May 16, 2011 | 10:41 AM
hobbsy3005's Avatar
yes its a pull out and it is always pulled out. im getting a new deck in the next couple days so ill make sure it plugged in all the way when i install it. if that doesnt work then ill probably just buy a new one
Stumasters
Aug 27, 2007 09:24 AM
jayrosen
Jul 27, 2007 04:37 PM
radioheadlive82
Jun 8, 2007 11:36 PM
akimity
Jul 2, 2005 09:07 PM
shorty3788
Nov 21, 2004 11:04 PM
