Any help appreciated!
Old Dec 4, 2018 | 07:20 AM
Abyss's Avatar
Default Any help appreciated!
I have a 94 civic ex and it's been giving me a bit of trouble. At first it would hesitate while accelerating but only when the car warmed up. Then a few days later it started having idle issues, the car would get really close to dying constantly. Replaced fuel filter, issue left for a day and came back. Replaced O2 sensor and same thing. Today it died when I tried to back it out of the driveway and cranks but no start. Any help would be greatly appreciated, thanks!
Old Dec 4, 2018 | 11:25 AM
udraft's Avatar
Sometimes the fuel pumps fail like this. O2 sensor should not cause no start.
Old Dec 4, 2018 | 12:18 PM
Abyss's Avatar
Okay I'll try and pick one up today. Also last time I tried to start it earlier, there was a POP that sounded like it came from the exhaust area so I'm worried maybe the CAT could be clogged...
Old Dec 4, 2018 | 01:25 PM
udraft's Avatar
Certainly a possibility, not sure how you troubleshoot clogged CAT.
Old Dec 4, 2018 | 01:26 PM
Abyss's Avatar
Thanks for your response! Will report back after the fuel pump is replaced. Update: no good...
Old Dec 5, 2018 | 07:03 AM
udraft's Avatar
It's usually best to try and test parts versus just buying them. We do our best to advise, but it is the interweb.....
Old Dec 5, 2018 | 02:01 PM
Abyss's Avatar
Yeah I probably should have done that. I appreciate the responses. Any other ideas?
Old Dec 6, 2018 | 07:55 AM
udraft's Avatar
Try some basic checks of primary (12v) and secondary (plugs,coil) ignition. Could even be a failing battery or engine timing (seems unlikely).
trobaked
Feb 26, 2009 09:47 AM
crazybolts
Dec 29, 2007 11:06 AM
k2rad
Apr 7, 2007 11:12 PM
breaux371
Oct 24, 2006 08:49 PM
silvercivicex98
Aug 24, 2005 08:49 PM
