Any help appreciated
Old Mar 1, 2019 | 10:00 AM
jeepcat65's Avatar
Default Any help appreciated
Hello and thanks ahead of time.I have a 94 civic that runs like a top as long as you keep the automatic trans from going into 4th gear overdrive.It will run all day long and not skip a beat in 3rd.But,the second you let it go into 4th gear overdrive,its like the key is shut off.The car acts as if brakes are applied,misfires, and dies.If you shift it back into 3rd while this is happening it straightens right up and runs great.Please help.Going crazy.Seems abit gas fumey as well.And oh yes,it seems to do it more often if the fuel tank is fuller.
Old Mar 2, 2019 | 08:39 PM
Dirtyskaterkid's Avatar
Get your fuel pump, egr checked out, could be a improper fuel mixture causing it to misfire and can cause it to run rough, possible the cause of the gas odor you're talking about
jmacook
Mar 28, 2013 05:52 PM
thisisa99honda!!
Jul 8, 2012 08:23 AM
DanoATX
Aug 13, 2011 01:51 PM
Capnx
Jun 1, 2010 04:39 AM
asechrist
May 26, 2009 09:51 AM
