Auto Radiator into a 5-speed???
Old Jun 13, 2006 | 06:35 PM
windcalmer's Avatar
Default Auto Radiator into a 5-speed???
Will a radiator with the two tubes coming out of it meant for an automatic trans work fine with a manual? I dont have the tubes hooked up, just plugged to keep them clean. I dont see any leaks, but when I drive around and then open the hood it feels "steamy" under the hood. Any help?
Also, if the radiator and the two tubes are two seperate systems, could you use it to cool your engine oil? Not that I would just wondering if it would work?
Old Jun 13, 2006 | 09:43 PM
ef4life's Avatar
Default RE: Auto Radiator into a 5-speed???
the radiator should be just fine, its for the auto trans cooler. i guess you could turn it into an oil cooler but it is extremely large so it might keep your oil below operating temp.
Old Jun 15, 2006 | 05:03 AM
windcalmer's Avatar
So what about using it to cool the manual tranny?
Old Jun 28, 2006 | 04:13 PM
Mushroom's Avatar
No need there. The manual tranny probably uses gear oil and doesn't need cooling. ATF needs to be cooled as well as the tranny itself in an automatic and also because it has rubber seals.
ndowens
May 10, 2012 09:11 AM
James Shaheen
ED-EF Swaps
Apr 11, 2012 06:09 AM
PunisherInOKC
Jul 3, 2010 05:12 PM
Ed Fisher
Jan 14, 2010 07:41 AM
klipschfan4life
Apr 24, 2009 03:25 AM
