Auto Transmission Hard shift low power
Old May 2, 2007 | 10:35 PM
opigonbad's Avatar
Default Auto Transmission Hard shift low power
91 Civic DX 1.5 Automatic 134,000. Taking off it seems to have decent power. When it shifts to the next gear it hesitates (rev longer than should) for a sec thenjerks forwardinto gear. This happens in each gear but gradually less as gears increase. It seems to have terrible staying power when going up inclines, loses speed pretty fast, really almost embarrasing, it then has to downshift.Is this a (microslipping of the tranny while going up incline).Also when coming to a stop it downshifts hard with the same jerk/thump as the acceleration problem. The fluid level is good, no leaks, and doesnt smell or look burned. Any experience with this type of problem? Any adjustments that might need to be checked?
Old May 2, 2007 | 11:35 PM
elusive_da's Avatar
Default RE: Auto Transmission Hard shift low power
ok this is what i would do.... pop the hood, look at the tranny right under the distributor, you'll see a little syolinoid.... take it off and clean it out, see that happens, that same thing happend to my 96 accord (daily driver) and this fixed it.... good luck
Old May 3, 2007 | 11:14 AM
opigonbad's Avatar
Pulled the selenoid, the screen looked good, cleaned it up. Still does the same. If it wasnt working at all would it cause these symptoms? What is the purpose of it anyway? Anyone else have a suggestion. Other than replace tranny.
Stuart1962
Aug 8, 2015 04:58 PM
Stuart1962
Aug 8, 2015 04:40 PM
RobertoK
Nov 27, 2010 03:42 PM
ChevyTruck
Sep 22, 2008 10:11 AM
H22CIV
Sep 27, 2006 01:13 PM
