b swap not starting
Old Jan 19, 2009 | 07:34 PM
ef846's Avatar
Default b swap not starting
i got a ls motor in my ef and it is not starting it has spark and fuel pressure and the main relay its brand new and it ran for about five minutes then i pulled it into the shop and turned it off and it wouldn't start after that and any sugestions would help
Old Jan 19, 2009 | 07:38 PM
How do you know that you have both fuel and spark?
Check whether the timing belt slipped.
Also, is the spark bright blue or weak orange?
Old Jan 19, 2009 | 09:19 PM
swopey's Avatar
yeah definately check the timing especially if you just put the motor in. My buddy did a b16 swap and it turned over the first time but wouldnt run after that. timing.
Old Jan 19, 2009 | 09:30 PM
jpnolan's Avatar
are you using a good harness or a crapily put together one. <--- that caused me some issues.
Old Jan 20, 2009 | 12:05 PM
ef846's Avatar
i checked the timing thats good but it thorwing a code 1 on the ecu but i know that o2 isn't hooked up the spark is white ish i am going to check the coil to see if that s the problem
Old Jan 20, 2009 | 12:21 PM
Do you hear the fuel pump prime? Have you measured the fuel pressure? Have you checked cylinder compressions?
When you eventually solve the no-start problem, purchase and install a new O2 sensor. Engine performance and mileage will be much improved.
totenkopf
May 31, 2007 03:36 PM
Impreza WRX
May 7, 2006 02:01 PM
SkeetFresh
Mar 13, 2006 08:11 PM
civiclsi
Nov 20, 2005 05:50 AM
fast93civic
Aug 22, 2005 10:27 PM
