b16 spudders?
Old Feb 21, 2006 | 07:35 PM
smokingemcee's Avatar
Default b16 spudders?
I was driving my car around today and it was warmed up and ready to go. I took it up to about 7500 rpm in 2nd gear and it just spuddered and kinda gave up like it hit a rev limiter. I have taken it to 8200 before so I know my ecu should be fine. Any idea what that could be? fuel pump? fuel filter? ignition problem?
Old Feb 22, 2006 | 12:20 AM
Whitelightning93's Avatar
Default RE: b16 spudders?
sounds like it could be something like detonation and/or pre-ignition. Hope this isnt the case though... goodluck
Old Feb 22, 2006 | 06:12 AM
it doesn't do it everytime I just noticed. I doubt that ****, I would be devestated! I think it my be my fuel filter. . . ..
Old Feb 22, 2006 | 02:16 PM
if it infact is your fuel filter, you can pick on up for about $12 bucks anywhere. A clogged fuel filter not only can waste gas, it makes your fuel pump over work itself and wear out a lot faster than it should.
Old Feb 22, 2006 | 06:28 PM
stuff444's Avatar
I think that you guys are probably on the right track...when the motor is up that high it is requiring large amounts of fuel and pressure, if it can't get it then you will start to run lean and the ECU should attempt to correct...unless you are at WOT in which case it will probably sputter as you put it or maybe screw up something worse it depends. Running lean is never good. I would try the easy things first before trying to tackle more difficult problems like valve springs or something. Good Luck!
Old Feb 24, 2006 | 10:34 PM
yeah, I'm going to get a high-flow fuel filter cause I'll be boosting soon, hopefully I'll have no probalems after that. . . . .
thatguywithahonda
Jul 3, 2013 07:36 AM
turbo speeder
Jan 28, 2009 03:57 PM
ss90skeeter
Aug 24, 2007 03:11 PM
b2usmc
Nov 28, 2006 12:51 PM
outlawzz23
Aug 9, 2004 08:21 AM
