d16 spudders
Old Nov 27, 2006 | 05:08 PM
b2usmc's Avatar
Default d16 spudders
my 94 civic d16 spudders on acceleration when warm...generally in second right after changing gears but it does it in all gears as well as an occasional spudder while just revving. i got new plugs and wires, timing adjustment, a new fuel filter, new air filter, oil change...but it still spudders. anybody??
Old Nov 28, 2006 | 08:24 AM
Default RE: d16 spudders
How many miles? Might want to consider running some Seafoam through it.
Also, where are you shifting (rpms)?
Old Nov 28, 2006 | 10:16 AM
SLVREJ8's Avatar
I had a similar problem once and it turned out to be my coil and plug wires.
Old Nov 28, 2006 | 11:56 AM
Pete's Avatar
Like tony said, try seafoam, I always try the most inexpensive solution first.
Old Nov 28, 2006 | 12:00 PM
ORIGINAL: Pete
Exactly, 90% of the times I've had issues, it was some piddly *** little solution that cured it
Old Nov 28, 2006 | 12:51 PM
kman92civicsi's Avatar
when are u shifting it is the most inportant and cheapest question. and cause if u go into second at 20 kmph and then shift too 3rd at like 30 kmph your car is gunna shake
fastrecklessracer
Dec 31, 2007 02:44 PM
ss90skeeter
Aug 24, 2007 03:11 PM
ohbiskits
Oct 23, 2006 08:30 PM
smokingemcee
Feb 24, 2006 10:34 PM
iceman56
Jul 1, 2004 08:46 AM
