B18b1 harness ques
even if the engine harness does plugg up would under the dash plus up 2 i totaly forgot about that, or if you can let me no what would be the best thing to do to make everything work properly.
thanks
thanks
you want to use the original engine harness that came in your car. detach it from your motor and put it on the new motor. then you buy the conversion harness and plug that into your underdash harness where your ecu is. you might have to modify your harness a little bit, but its not that bad. i had to convert my civic from obd 0 to obd 1 and wire the car for fuel injection. but your already half way there.
