B18B1 Turns over but won't start
Old Jul 11, 2010 | 11:05 PM
00Si_Bennett's Avatar
Default B18B1 Turns over but won't start
Threw a rod (B18B1) a couple weeks ago. Ordered a new(ish) B18B1 from Apollo Motors out of Chicago. It got here, looked fine, etc. Installed it, everything went as planned. Went to start it up, it just sat there and turned over, didn't start. Here's everything we've checked:
Spark - check
Fuel flow - check (has gas in the cylinder or at least a gas smell on the spark plugs)
Ignition system - changed the distributor from the old engine to the new engine, etc.
Timing - checked
Compression - checked
I may be missing things, but it seems like everything was checked and it still won't start. Any ideas? FYI these were trained mechanics that were performing these checks with their tools and sensors, not just backyard mechanics. They do engine replacements all the time, and they're scratching their heads. If someone has some advice it would be MUCH appreciated. I'm stranded in Arkansas til it gets fixed.....
Old Jul 12, 2010 | 03:10 AM
Check for distributor installed 180 degrees out of time(*), or spark wires in wrong order.
(*) and don't let anyone tell you that's not possible, I've done it myself (on a D15 anyway.)
Old Jul 12, 2010 | 04:38 AM
Definitely check the firing order of the plug wires on the distributor cap and of the fuel injector connectors on the injectors. In addition, some aftermarket distributors can be installed 180-degrees out of phase.
Old Jul 12, 2010 | 06:55 AM
Every one of those has been checked already. Just got off the phone with the mechanic and he said now it'll start but it's out of time, even though the belts and distributor and showing that it should be in time. Doesn't sound good to me. Hoping the engine isn't messed up....
Old Jul 12, 2010 | 03:34 PM
Turns out they didn't check compression in all cylinders. Number two didn't have any. Took it apart and found a rocker arm was off. FYI.
tylergarcia
Aug 10, 2015 09:11 AM
johnpg1957
Mar 14, 2012 04:32 PM
wantacivicwagon
18
Jul 25, 2011 02:18 PM
Liddy-b
Jun 23, 2011 10:44 AM
ThunderStump
May 19, 2009 10:21 PM
