battery drainage
Old Jun 11, 2012 | 09:11 AM
mycam8u2's Avatar
Default battery drainage
i was wondering if there is any known problems on a 2000 ex 1.6 sohc that causes the battery to be drained if it sits for a few days. i cant figure it out and really dont know how to figure it out. if the car sits for like 3 days the battery will be completely drained. can someone please help?
Old Jul 10, 2012 | 01:54 PM
mycam8u2's Avatar
Old Jul 10, 2012 | 03:27 PM
Check for dome or trunk light not going out. If there's an aftermarket audio system, the amplifier may not be shutting down properly, which will drain the battery.
First check the charging system by measuring the voltage at the battery with the engine running but everything else off. It should be more than 14 volts. If the battery never charges fully it's going to seem like it is run down.
A test to try is to disconnect the battery after you park when it is going to be parked for a while. If the battery is dead upon your return, the battery is running down by itself because it is defective.
Old Jul 10, 2012 | 07:41 PM
MistaGlock's Avatar
you have parasitic drain homie. have a look here How To Perform a Parasitic Draw Test - YouTube get a multimeter and have at it. this will solve your problem
adamcotta
Aug 13, 2014 05:47 AM
Knobmeister
Apr 14, 2012 05:47 AM
addiction2bass
Jul 24, 2006 08:57 PM
C1v1c
Jun 14, 2006 03:48 PM
loyolarobyn
Nov 13, 2004 11:54 AM
