Battery goes dead on ilde
Old Dec 12, 2008 | 04:04 AM
genexxa's Avatar
Originally Posted by mk378
Check that battery voltage is reaching the I wire on the alternator with the key on (engine not running). If not, it's that darn fuse 15 circuit again. That usually causes other problems like the speedometer not working and the CEL on though.
THANKS!!!! you know what!!! my speedometer is not working!!! I'll take a look tonight and try to change that fuse...
Old Dec 12, 2008 | 06:19 AM
If you find the fuse blown, it's almost certainly because because the wires behind the engine (where they go across to the alternator) are frayed and shorting out. You'll need to fix the wires or the fuse is just going to blow again. It is a known common problem on the '98.
Old Dec 15, 2008 | 07:45 AM
genexxa's Avatar
Thank you mk378... you were right on... the fuse was blown... I changed the fuse... everything is working fine now and my speedometer is back...
I'm just wondering how long the fuse will hold on... only time will tell!!!!
Thank you!!!
Old Dec 15, 2008 | 05:41 PM
mundy5's Avatar
genexxa,
unfortunately you have only put a band-aid on something that requires more work. I recommend that you go to RonJ's post and look at his signatures. One of the links is the Common fuse 15 link. it will give you all the instructions you need to fix this problem once and for all.
wil
Jan 18, 2013 04:27 AM
Peg_Leg
XBox/XBox 360
May 7, 2010 06:42 PM
camarossguy2
Aug 20, 2008 01:00 PM
AnimalWild
Jun 27, 2008 11:46 AM
