Battery Light Is On
Old Jan 27, 2007 | 11:07 PM
  #21
JayG523's Avatar
Default RE: Battery Light Is On
I ran a code scan that my brother-in-law has and it gave me no DTC's or error codes found. Could this be a bad ECM or even dash?
Any help would be greatly appreciated.
Old Jan 28, 2007 | 07:37 PM
  #22
Impreza WRX's Avatar
Maybe the test wire that goes to the charge dead light is faulty. This is the FIRST thing that you check, according to the Honda book. Get your Honda book out, and it has a flowchart to help you troubleshoot (including what wires to pull where).
Old Feb 17, 2007 | 09:56 AM
  #23
civic2001's Avatar
Was this problem ever resolved?
Old Aug 28, 2018 | 05:07 PM
  #24
RageLikeReptar's Avatar
Was this ever fixed I have the same issue
Old Nov 25, 2019 | 11:21 AM
  #25
Jarclanger's Avatar
Default Fixed
pulled the 7.5 amp fuse bottom right under the dash and left it out. Light is off. (Fuse #10)
Old Sep 24, 2024 | 09:14 AM
  #26
cesarmalave25@gmail.com's Avatar
Default It’s ecm
Originally Posted by Stumasters
I have always read and heard that if the battery light is on, it means one of two things,
A. the Alternator is not charging
B. the Battery may be defective.
I see you have already investigated the obvious so your on the right track.
Have you used a tester to verify that the alternator wiring is not defective in some way, running from the alternator to your battery, or maybe a loose or bad ground?
Have you contacted a dealer over the phone with similar questions?
These are the only 2 questions that come to mind, I haven't had alot of electrical issues over the past few years, but I know loose wires often cause a painstaking problem. You might try a tester and check the wiring to and from the alternator, and perhaps monitor the battery over the course of a day or so, see if the sitting voltage drops alot for no reason, you might have something grounding or a faulty switch somewhere causing the light to be on.
it’s the ecm alternator signal fried
Old Sep 27, 2024 | 04:13 PM
  #27
hodida's Avatar
Default Battery Light Is On
you should check the wires first
Stephen Korkis
May 7, 2019 03:10 PM
Ragedude
Jun 5, 2017 04:50 AM
Ragedude
Jun 5, 2017 04:49 AM
jacksmash
Jan 27, 2010 06:46 AM
learjetcowboy
Apr 19, 2007 05:18 AM
