Battery?you can read this one.\!?!
Ok,guys My car is a 94 honda civic, Aight this morning I went out to go to school and I got in my car and turned the key and it hesistated a little
I turned the key and it spun over and then slowed down and then fired right up. I only had to turn the key once.
This is the first cold day of the season here it dipped down to about 1 degrees here. could the cold be zapping my battery? Could I be out of cold start amps? If I am how can i measure this. Help me guys thanks
get your battery tested. when they are cold, the amps do go down quite a bit. and remember to test your coolant to make sure its good down to those temps. thats freakin cold. it never seems to drop below about 30 degrees here, and thats usually only for an hour or so in the mornings, and only for a couple of days a year. sometimes i like going to the higher country, like Reno and Tahoe, just to breath in the 5 degree air. something cleansing about it.
A nice trick to try sometime if you have some halogen work lamps sitting around is to just leave one of those puppies on under your oil pan overnight. Rent-a-block-heater. You car will love you for it in the morning.
or get one of these:
OPTIMA Batteries® EXPANDS LINE TO FIT SPORT COMPACT MARKET
For the last eight years, OPTIMA Batteries‚ has been the power supply of choice for on-road and off-road racers, 4x4 enthusiasts, hot rodders and car audio enthusiasts. Now, the sport compact market can also take full advantage of OPTIMA’s patented SPIRALCELL Technology®. OPTIMA Batteries is introducing the Group 51 YellowTop™ battery, designed to OPTIMA’s high quality specifications and built to fit the Honda Civic, Acura Integra and other imports. Unveiled officially at SEMA’s International Auto Salon in Los Angeles, the Group 51 YellowTop has been greatly anticipated by a large contingency of import tuners, racers and audiophiles.
Knobmeister
Apr 14, 2012 05:47 AM
addiction2bass
Jul 24, 2006 08:57 PM
Cutt
Feb 11, 2006 04:38 PM
b3nSoNx
Oct 5, 2005 04:16 PM
