Best way to clean inside of transmission housing?
As some may know I am in the process of converting my car from auto->manual.
Long story short, the transmission I bought seems a little dirty in the bell housing (I think thats what its called)
Its the area around the main gear shaft thing (lol) thats sticking out, also the part that mates the pp/clutch/flywheel with the motor.
What kind of solution should I use to clean it?
Get 5-6 bottles of brake cleaner (degreaser, gunk gone...), a garden hose with a water connection, and a mask for you.
Spray on some brake clean
Blast it off the gunk with the hose
Repeat until the gunk is gone.
This is bad for Mother Earth, so if you could, do this in a garage with the proper drainage, if you can.
W3rd. Spray some brake cleaner on it, and let it drain into an oil drain pan underneath. The loose stuff will come off and run into the pan. If there's some oily 'runs' or areas of collection, investigate to make sure they're not there because of seepage through the tranny seals.
Otherwise, don't waste too much time on it, like mk378 says.
Scott53092
Sep 7, 2009 08:38 PM
STREETFIGHTER50
Mar 24, 2009 08:09 PM
blk04cleancivic
Feb 4, 2008 08:51 AM
Forty04
Jul 11, 2005 08:24 AM
