Bottomed out HARD.
Old May 10, 2010 | 09:58 PM
Heringer91's Avatar
Default Bottomed out HARD.
1998 Honda Civic Si 2Dr Coupe (Yes Si, i'm from Canada (and our winters leave nice big huge death traps on crappy roads!) )
The civic is lowered with coilovers, and is about ~4.5 inches off the ground
I was going around a corner today, and i hit a big pot hole that i didn't see, it was kind of a weird one, as my front wheels both dropped in, but my bumper didn't touch, but under the passenger side, hit HARD on the edge of the hole. the back wheel was off the ground, and it took 4 people to push it backwards because the fronts just spun. When i open the passenger side door, it clicks with the front fender, but i fixed that by putting a screw driver and moving the fender slightly., is there anything i should b worried about breaking under the car? it missed the exhaust pipe, but pretty much all the weight of the car was on the area between the pipe and the edge of the car. (Basically right under the passenger door in the center) Like any lines that could be pinched? or any parts that could be dented? or broken?... there is what looks to me like a metal "shield" there, but it does have sort of a curve in it now, where it was sitting on the edge of the hole.
Sorry about the novel any help appreciated!
Old May 11, 2010 | 08:09 AM
Mad7s's Avatar
Oil pan
Old May 11, 2010 | 09:28 AM
Those two "rails" formed of the sheet metal under the car are an important part of it's structural integrity. There's nothing inside but they act like a box beam. The fact that the door doesn't work properly suggests that the whole "frame" of the car is bent.
Old May 11, 2010 | 04:53 PM
Heringer91's Avatar
i dont think it was hard enough to bend the frame,as as for thr door not working properly, it does, it just slightly tocuhes the fender when you open it, it still closes properly, it just barly nicked it, not even enough to rub paint off
Old May 13, 2010 | 05:24 PM
civicexracer's Avatar
There are brake lines that run to the rear brakes, that's about the most serious thing that could have been damaged.
Old May 13, 2010 | 05:47 PM
plethoric33's Avatar
Thats a hell of a pothole. You might want to get it up on a jack and take a good look.
Old May 15, 2010 | 02:17 PM
Heringer91's Avatar
I made sure that wasn't pinched as soon as i got it off, it missed them completly, it was further under where it was sitting.
ProStreetDriver
Jul 3, 2008 11:14 PM
asechrist
Jun 27, 2008 07:43 PM
addiction2bass
Feb 18, 2008 06:01 PM
pairenoid
Feb 17, 2008 09:50 PM
