Brake pedal losses pressure
Old Apr 27, 2013 | 01:56 PM
RunNRhino's Avatar
Default Brake pedal losses pressure
My 99 EX has not had any brake worked performed in the last 3 months since I put new pads up front and everything gas been working fine. Today when I applied the brakes the pedal nearly went to the floor. The rest of the 8 mile trip home it would do the same thing when intially applying pressure, then would get stiff upon pumping a couple of times. The front calipers look dry and fine. I followed the lines and they look dry and the fluid is not low, actually at the top range. Not sure what else to check.
Old Apr 27, 2013 | 03:03 PM
If it's not a leak or air in the lines, the master cylinder is bad.
Old Apr 28, 2013 | 08:27 AM
RunNRhino's Avatar
Thanks Mk. Is there a way to tell if its the master cylinder or the booster?
Old Apr 28, 2013 | 09:09 AM
Bad booster the car will still stop though you'd have to press very hard on the pedal. So it's not that.
vwhater
Jun 27, 2016 06:04 PM
lunger
Jul 10, 2011 02:50 PM
Ed Fisher
Aug 20, 2009 11:47 AM
phan10m
Jul 7, 2007 04:27 PM
loFreqncy
Jan 20, 2007 06:32 PM
