brake problems
Old Apr 20, 2008 | 11:04 AM
crolback's Avatar
Default brake problems
We just put new brakes,rotors and calibers on my 2004 honda civic dx. It still vibrates and acts like the breaks are still dragging and running hot. Any suggestions. Someone told me it could be the mastercylinder?
Old Apr 20, 2008 | 11:10 AM
sacicons's Avatar
Default RE: brake problems
did you grease the sliders?
Old Apr 20, 2008 | 03:17 PM
crolback's Avatar
Yes, everything is brand new. Brake pads,rotors,and calibers.Sometimes when I dirve it,it will be just fine. Then it starts to vibrate the sterring wheel and you can smell the breaks. I've parked it for now till I can figure out what's up.Someone told me the next thing to try is the mastercylinder? Could that be causing this?
Old Apr 21, 2008 | 05:15 AM
A partly clogged hose can cause the brakes to drag. If it happens on both sides it's probably not that though. So when it acts up see if it is one wheel or both.
Once the brakes have dragged and overheated a rotor, the rotor is warped and needs to be replaced again.
Old Apr 21, 2008 | 05:21 PM
crolback's Avatar
Well, I know it's both wheels. They smell hot. Were going try the matercylinder and blow out the lines, see if that works i guess.
Old Apr 23, 2008 | 04:09 PM
crolback's Avatar
Thanks. We are going to work on it this weekend. Someone also told me that the rubber lines that connect to calibers could be clogged, might not be able to see it for the outside. They could be clogged inside the tubes. Thanks again.
Ed Fisher
Aug 20, 2009 11:47 AM
Cosworth
Dec 15, 2008 05:35 AM
burgernuds
18
Aug 16, 2008 07:20 PM
j2performance
Jan 15, 2008 01:48 PM
Stumasters
Jan 17, 2007 01:36 AM
