buring oil?
Old Jul 19, 2007 | 12:15 PM
Rklamb16's Avatar
Default buring oil?
If my car is buring oil quickly how do i fix it?
Old Jul 19, 2007 | 12:25 PM
BlackEM1's Avatar
Member
Default RE: buring oil?
burying oil? take the shovel away from the car.
burning oil? get your piston rings replaced. That'll be big money. Might as well build the engine while you're at it.
Old Jul 19, 2007 | 12:26 PM
Umm, replace the engine. Check that the PCV valve is not clogged but that's usually a symptom of a worn-out engine and not the direct cause of burning oil.
Old Jul 19, 2007 | 12:29 PM
Mr Mobsta Man's Avatar
Are you sure it's buring it? Your not leaking anywere? What color is your coolant? Have you done a compression test?
Seafoamgreencivic
34
Aug 12, 2008 09:30 AM
oilltd
Jun 10, 2008 04:06 PM
DotComx
Dec 24, 2005 04:06 PM
smokingemcee
Jul 12, 2005 01:28 AM
