Burnt out switches?
So i have two switches wired into the same wire going to the fuse box. Ones for underglow and ones for under dash neons. I had my underdash neons on (the swtiches have LEDs on them btw), and then i flicked to the underbody neons on and they came on for a second then both teh switches shut off (no LEDs on, no neons on). I thoguht i just blew a fuse, but looked under there and noticed that the fuse was in perfect condition. Is it possible to burn out switches? They're just cheap $5 Wal-Mart swithces with a Green LED on them. Think i just ran too much current through them? Never happened to me before, i mean i've had both underbody and underdash neons on at the same time quite a bit. Ideas?
Do they work now? As long as they are 12V automotive switchs they will be fine, i used wallmart switches before and they were fine. Its the way you have it hooked up, I would make sure you have the right size fuses in there.
no, when i turned both the switches on everything shut off. No LEDs on the switches and no neons on. Yeah i guess i could just check with a voltmeter eh? haha my bad you guys, i'll check tomorrow
