a/c blows cold then hot
I had this same exact problem.. spent tons of money replacing stuff like the compressor, and then money to get it vacuumed and recharged, only to find out that wasn't the problem like they told me it was. Don't go through what I did...
It's the compressor relay!
+1 on the compressor relay! I had the same problem in my 92 EX.
When the AC stops running, pop the hood and look for the relays on the driver's side front, attached to the core support.
When the AC isn't working, try thumping that relay with your fingers. If you hear a loud CLICK (compressor clutch engaging) and suddenly your AC works, there's your diagnosis.
Be sure to replace BOTH the compressor clutch and condenser fan relays. If one is bad, the other isn't far behind. If you're at a standstill with the AC running and you have no condenser fan, your compressor could blow up.
Slammed98silvercoupe
Sep 24, 2012 10:30 AM
TexusMain
Jun 14, 2012 04:40 PM
staffordgt
May 8, 2009 11:22 AM
general23cmp
Dec 20, 2008 10:43 PM
SiX
Mar 12, 2008 12:14 PM
