A/C Cold then Hot?
A pressure of 200 on the low side is just way wrong. Assuming that you're measuring properly (hand wheel valves on the manifold CLOSED), the only way this can happen is to have air or other non-condensible gas in the system. To know where you stand, it must be evacuated and recharged with the proper amount of new refrigerant. Also consider the possibility of too much oil, or sealer in the system.
It may fix it or it may not, but either way it's the first thing that needs to be done. You need to be sure there is no air and a proper charge of refrigerant first in order to diagnose any other problems the system may have.
jenkent527
May 1, 2013 02:44 PM
general23cmp
Dec 20, 2008 10:43 PM
SiX
Mar 12, 2008 12:14 PM
Act of God
Jan 20, 2007 04:53 PM
