A/C fan stuck on full blast
Old Apr 30, 2012 | 07:09 AM
hobbsy3005's Avatar
Default A/C fan stuck on full blast
pretty much what the title says. the fan never turns off full blast, even when the ac is off
Old Apr 30, 2012 | 07:37 AM
This is probably the power transistor. Located behind the glove box, it controls power to the fan. I think models 1998 and later have one instead of the old resistor system. If other stuff on the control panel (such as the air outlet selection) doesn't work either, the control panel could be bad.
Old May 1, 2012 | 04:02 AM
hobbsy3005's Avatar
Is there an easy way to check if thats the problem and fix it? Or will I have to buy a new one
Old May 1, 2012 | 05:22 AM
Unplug the transistor and measure the resistance between its two terminals that go to the large wires in the car. If it is zero ohms, the transistor is shorted.
You should also turn the key on with the transistor unplugged and confirm the fan does not start. That doesn't prove the control panel is OK though.
tyler2004ex
Feb 12, 2017 08:53 AM
kcorwin
Nov 25, 2013 03:54 AM
alpinegroove
36
Oct 29, 2013 08:07 PM
lillyrat
May 22, 2007 09:31 PM
2006HondaCivic
Feb 21, 2006 10:15 AM
