A/C idler pulley tensioner location
Old Mar 11, 2012 | 10:58 AM
txpro's Avatar
Default A/C idler pulley tensioner location
Hey, I'm trying to figure out how to adjust the a/c tensioner on a 94 civic hatch dx so I can remove the belt. I've been searching online and all of them have the idler pulley above, not below. They say there is a tensioner bolt looking down near the compressor and engine, but I cannot find it or know if I have one. I took a few pictures of it from the top and bottom. If anyone could point out what I need to do, that would be awesome. Thanks
ac belt - Imgur
Old Mar 11, 2012 | 11:12 AM
What you have is not stock, it is a homemade setup. Thus you are on your own with it.
The rusty steel welded thing is a custom adapter plate. The compressor is not the stock type.
It looks sort of like a spring-loaded tensioner common on American cars. Maybe just loosen the bolt that holds it to the rusty adapter plate?
Old Mar 11, 2012 | 11:27 AM
txpro's Avatar
Thanks for your quick reply MK. Are you talking about that giant bolt holding it to the pulley adapter? Turns out the compressor is made by Tama Mfg.
Old Mar 11, 2012 | 02:24 PM
Yeah that's what I'd try, though I haven't seen a tensioner exactly like that. It looks good for a homebrew job but the design is kind of wonky. Since the engine rotates counterclockwise, the tensioner is on the taut side of the belt, which usually isn't a good idea.
Old Mar 11, 2012 | 04:21 PM
txpro's Avatar
Thanks for your pro input.
boiler1
Jun 8, 2011 05:39 AM
canyonmom
Apr 3, 2010 06:53 AM
canyonmom
Feb 8, 2010 07:24 AM
og_281
Sep 4, 2008 08:07 AM
haole
Sep 8, 2007 04:53 PM
