Camber Kit Dilemma
Old Jan 10, 2012 | 09:02 PM
DroppedCivic94's Avatar
Default Camber Kit Dilemma
What's up HCF...my civic dx is lowered with DZ Racing coilovers bout 2 to 2.5 in the front and about the same in the back..I blew on tire already(front passanger) and its only getting worse..I have a camber kit on the way..its alittle on the cheap side but with two kids and rent to pay I have to take what I can get...anyway I checked a few threads on the site and it seems to me that the alignment is more important..so should I run my stock hardware with a alignment done or should I install the camber kit and do the alignment??..
Old Jan 11, 2012 | 04:07 AM
Bad alignment doesn't make tires suddenly blow out. It will wear the tread off. But, I suppose if you keep going until worn completely through...
Old Jan 11, 2012 | 05:13 AM
It wasn't a sudden blow out..I guess I just didn't know wat I was looking at at the time...the wear looked fine...then I got the flat..but to me my tire always looked flat..I guess that's called "toe"...im still relatively new to car mods...after the tire was off I saw the uneven wear..
Old Jan 11, 2012 | 05:32 AM
The main reason i need a alignment is I'm getting a lot of steering wheel vibrations when I'm on the highway...and it pull heavy to the right..
larring1020
Dec 8, 2006 12:55 AM
Saviourkakashi
Nov 7, 2006 12:05 PM
00civicEX_3
Feb 10, 2006 02:44 PM
skytanker2003
Dec 20, 2005 08:29 AM
spills_9
Jul 6, 2005 09:07 PM
