car stutters slightly and randomly
Old Apr 18, 2007 | 05:43 PM
Ashtrey634's Avatar
Default car stutters slightly and randomly
hey i got a stock 97 ej8. i just got my timing belt kit, water pump, oil change done last week and adjusted the valves, fixed my fluctuating idle problem and put some seafoam in the gas tank and through the brake booster line a couple days ago. (smoked like crazy) anyway i noticed yesterday and today that when i brake at very low rpms in first gear (when stopping at a light or in traffic) my car starts to stutter back and forth slightly, enough that i can feel it but nothing real major. i have almost 83k miles on the car. im thinking its bcuz im due for a tune up, (cap+rotor+plugs+wires) but not 100% sure, any other suggestions?
Old Apr 18, 2007 | 05:51 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: car stutters slightly and randomly
It could be due to a bunch of different things. Check plugs, wires, fuel filter, and/or for possible intake manifoldleak
Old Apr 18, 2007 | 06:23 PM
Ashtrey634's Avatar
just drove it again now, it seems like it stutters after i slowly RELEASE the brake while its rolling real slow.
Old Apr 18, 2007 | 06:41 PM
Ashtrey634's Avatar
also the car shakes a lil at idle, more when in first, and not as much when in reverse.
Old Apr 18, 2007 | 07:14 PM
kokasian's Avatar
it shakes at idle because its too low and the car is trying to stall. the vacuum that the brakes pull on the engine can also make the engine lug a little if the idle isnt right
Old Apr 18, 2007 | 07:23 PM
Ashtrey634's Avatar
whats the rpm range supposed to be when the car is at idle?
Old Apr 18, 2007 | 08:34 PM
Ashtrey634's Avatar
when car is warmed up, my idle is at 500 i guess, theres no line, but its almost exactly in the middle of 0 and 1.
Old Apr 19, 2007 | 01:17 AM
hatch46580's Avatar
who did the adjusting of the valves. were they seated correctly?
Old Apr 19, 2007 | 06:53 AM
Did you run any of the seafoam through your crankcase? And if so, did you change the oil soon after? If not, thats always a good idea. With all the crap that the Seafoam brakes up, you want it out of your motor ASAP.
As you said, finish your massive tune up project (cap, rotor, plugs, wires) and if the problem persists, we'll have to look at other options
Old Apr 19, 2007 | 02:02 PM
Ashtrey634's Avatar
honda did the valves, the tech said the first 2 times they were too tight and timing was off and the 3rd time he got it. i only put seafoam thru the brake booster line (1/6) and the fuel tank (1/6). i didnt wanna do it all at once.
PuterChickFL
Sep 24, 2009 10:36 PM
Gen5unknown
Jan 10, 2008 05:41 PM
incogneato
Jul 30, 2007 12:17 PM
Ashtrey634
May 11, 2007 03:26 AM
Drunkgoose
Apr 19, 2007 12:37 AM
