car wont start
Old Jun 18, 2007 | 08:34 AM
adam 25's Avatar
Default car wont start
it sounds like it wants to start but it wont i was seeing if it was an ecm problem
Old Jun 18, 2007 | 08:39 AM
burnindesirez02's Avatar
Default RE: car wont start
first of all check to see if you are getting spark to the plugs and check for fuel pressure at the fuel rail.
Old Jun 18, 2007 | 09:17 AM
adam 25's Avatar
we checked that and everything is ok with that we also checked all the volts and im getting volts out of everything but the check engine light stays on
Old Jun 18, 2007 | 09:30 AM
it might be the ecu then but im not sure. what year?
Old Jun 18, 2007 | 09:46 AM
adam 25's Avatar
1992 civic hatchback the one day i was driving it later that night i went 2 go home and it didnt start
Old Jun 18, 2007 | 10:01 AM
adam 25's Avatar
Default ecm
if the one of the numbers are different on the ecm would it make a differance my numbers are 37820-p06-a50 and the one i found the last numbers are a52
Old Jun 18, 2007 | 11:42 AM
cderalow's Avatar
Default RE: ecm
well i believe A50 denotes an AT ecu..
A52 denotes the MT ecu?
This much I know for certain
if you're running an AT ecu in a MT car, it won't start correctly (ECU will be looking for a "car is in park" sensor message, but obviously won't be receiving one)
and vise versa (ECU will look for "clutch is depressed" sensor message)
David_S
Oct 24, 2013 10:06 AM
...NEED4SPEED...
Apr 20, 2010 03:55 PM
bmelloh
May 16, 2009 08:01 PM
niteryder
Dec 29, 2004 06:47 PM
89 pos
Jun 25, 2004 05:35 PM
