CEL from O2 Sensor
Old May 5, 2008 | 06:02 PM
Default RE: CEL from O2 Sensor
ORIGINAL: mk378
If you get a varying voltage on the output wire of your secondary sensor but the computer still throws the "sensor" code, your catalytic converter may be bad.
If believe in this case, a P0420 code would be thrown.
Old May 6, 2008 | 06:42 AM
nealkal's Avatar
I don't remember the exact code I was getting, I'll have to check again. Tonight I'll see if there is any voltage going to the secondary sensor. Thanks for the help!
Old May 6, 2008 | 01:41 PM
nealkal's Avatar
The secondary o2 sensor flutuates from 0 to .5 volts ever few seconds. But the primary sensor says at about .6 only moving slightley. Would that mean a problem with the cat?
Old May 6, 2008 | 01:50 PM
I believe that the secondary sensor or its circuit is faulty because the voltages of the secondary sensor should never fluctuate more than than those of the primary sensor.
Did you determine the specific code being thrown?
Old May 8, 2008 | 07:13 AM
nealkal's Avatar
Turns out the computer just needed to be reset. Disconnecting the battery doesnt completley reset it. I took it in to my mechanic and he reset it with some device.
Aaron Beausoleil
Mar 21, 2012 09:16 PM
NIKE H34D
Jun 5, 2009 05:53 PM
that_guy5
May 13, 2007 02:45 PM
tmduck
May 12, 2007 01:17 PM
addiction2bass
Aug 26, 2006 03:46 PM
