Chain or not
I love these descriptions of the sounds that people's cars make. How are we supposed to even begin to guess what it is? There is no chain anywhere on a Civic. The most common metallic sort of sound is the exhaust heat shield rattling. This will be heard from underneath the car near the center.
there is no code 16 for obd0 recount your blinks.
Note: OBD0 is for ECUs in the years 1988 - 1991.
Self-Diagnosis
Indicator BlinksSystem Indicated
0ECU
1, 2 Oxygen Content
3,5 Manifold Absolute Pressure
4 Crank Angle
6 Coolant
7 Throttle Angle
8 TDC Position
9 No. 1 Cylinder Position
10 Intake Air Temperature
13 Atmospheric Pressure
14 Electronic Air Control
15 Ignition Output Signal
17 Vehicle Speed Sensor
21 Spool Solenoid Valve
22 Oil Pressure Switch
43, 44 Fuel Supply System (KX, KS, KG)
If codes other than those listed above are indicated, count the number of blinks again. If the indicator is in fact blinking unusual codes, subsitute a known-good ECU and recheck. If the indication goes away, replace the original ECU. The Check Engine warning light and ECU LED may come on, indicating a system problem, when, in fact, there is a poor or intermittent electrical connection. First, check the electrical connections, clean or repair connections if necessary. If the Check Engine warning light is on and LED stays on, replace the ECU.
Self-Diagnosis
0ECU
1, 2 Oxygen Content
4 Crank Angle
6 Coolant
7 Throttle Angle
8 TDC Position
on obd1 and obd2 systems yes code 16 is fuel injector.
yours is obd0
do you have dual point?
92- and up
-----CEL # List-----
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
yours is obd0
92- and up
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
67 Cat Converter
80 EGR Valve/Line
The dual point system has 2 fuel injectors on the throttle body. Atop the throttle body is a black air box that says "dual point." The MPFI system (better) has 4 injectors in the manifold near the head, one for each cylinder. I think in 1988-91 models only the Si had MPFI.
