check eng light, low idle/stall, code PO135, HELP
Sorry, I forgot to upload the second page of the coolant bleeding procedure. Don't drain the coolant. Start at step 8 below with cold engine and heater lever in Max heat position:
Well, Ron, I thank you again for your help. Fortunately, it wasn't needed this time. For the idiot that's typing this was the culprit!
I took a closer look at everything and saw the problem. I didn't plug the map sensor back in!
Yes I'll be man enough to admit it, but I do thank you again for all the help.
A positive thing did come out of all of this tho, I know now what a map sensor and iacv do and where they are located
I guess we all learn sometime.
I guess we all learn sometime.Thread
SoCalEX
Aug 30, 2008 11:39 PM
cornerblitz59
Aug 27, 2006 01:15 PM
