Check Engine Light
Old Dec 19, 2005 | 08:19 PM
Shinumura's Avatar
Default Check Engine Light
I just had a tune up, dizzy cap, spark plugs, fuel filter. And about a day later engine light comes on. I try to pull the code but it keeps flashin 9 times. Thing is the engine light comes up only when the car is warmed up. when its cold doesnt come up. Anyone know what it could be?
Old Dec 19, 2005 | 09:06 PM
finalimpact's Avatar
Default RE: Check Engine Light
#1 cyl position sensor. its in the distributor and for the most part not reaplacable. check your distributor wiring plug too see for any loose connections.
Old Dec 19, 2005 | 09:20 PM
Shinumura's Avatar
What if i just replace the distributor ?
Old Dec 19, 2005 | 11:15 PM
if the problem is not caused by a loose wire then you should be fine. try resetting the ecu first and see what happens.
Old Mar 2, 2006 | 08:13 PM
Shinumura's Avatar
The problem still persists, i tried resetting the ECU but no luck. Can i fix the problem by replacing the Distributor?
-thanks for help
Old Mar 5, 2006 | 10:45 AM
Shinumura's Avatar
Please, can anyone help me?
miguel11691
Nov 15, 2015 08:11 PM
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
Benny Sim
Jul 19, 2005 07:43 PM
