Check Engine Light
Old Jan 12, 2008 | 05:13 PM
lawlersauce's Avatar
Member
Default Check Engine Light
Sometimes (usually when accelerating up a hill/onramp) my 93 ex accellerates SIGNIFICANTLY slower than normal (that is on hills) and then the Check Engine Light pops up. I noticed that it happens when I'm pushing the gas a little harder than normal. I don't know about that though, because for a 15 year old car on 138k miles, it's pretty responsive and can take some beating.
When I turn the car off and back on the light isn't on anymore, so I'm assuming it isn't a HUGE problem. But still...i don't like that evil red light staring at me while I drive.
This only happens every once in a while, like maybe once every one and a half months. Maybe some of you guys could give me insight on what this might be?
Old Jan 12, 2008 | 05:37 PM
Default RE: Check Engine Light
Retrieve the Check Engine Light (CEL) code as described here:
http://www.honda-tech.com/zerothread/1901557
Clear the code and, when the CEL again turns ON, retrieve the code to determine whether it is the same as before. Any repeated code will likely help identify the problem. Post your code(s) in this thread for more advice.
Old Jan 12, 2008 | 08:27 PM
Member
I'm not sure if that will work, because it involves turning the car off...and when I turn the car off the CEL won't show up again.
Old Jan 12, 2008 | 08:30 PM
When the CEL turns ON, the code is stored in the ECU. Even if the CEL does not remain lit, the code should still remain in the ECU.
miguel11691
Nov 15, 2015 08:11 PM
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
Benny Sim
Jul 19, 2005 07:43 PM
