Check engine light
Old Sep 23, 2009 | 06:03 PM
sincitycivic's Avatar
Question Check engine light
Our 1990 Honda Civic has been running great. We have to smog it in order to get the license renewed for the year. We took the car to the smog station and when the guy started his smogging procedure he told us that the car failed. We had driven the car without the check engine light coming on all year and when the smog guy started testing the car the check engine light came on. His guess was that the oxygen sensor wasn't working and suggested that we change it out. We went and bought a new one and installed it. Back to the smog station we went and we still failed. Now the check engine light is coming on full time. We looked at the computer and counted one red flash followed by 6 red flashes. We have 2 computers so we took out the existing computer and replaced with the extra one. This computer is giving us the check engine light with 5 red flashes. Does anybody know what these flashes mean? Thanks.
Old Sep 23, 2009 | 06:07 PM
1: Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
2: Oxygen Sensor "B"
3: MAP Sensor (Manifold Absolute Pressure)
4: CKP Sensor (Crankshaft Position Sensor)
5: MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
6: ECT Sensor (Engine Coolant Temperature)
7: TPS (Throttle Position Sensor)
8: TDC Sensor (Top Dead Center)
9: CYP Sensor (Cylinder #1 Position)
10: IAT Sensor (Intake Air Temperature)
12: EGR Lift Sensor (Exhaust Gas Recirculation)
check the hoses, the EGR valve lift sensor and the System EGR valve.
13: BARO Sensor (Atmospheric Pressure)
14: IAC Valve (Idle Air Control)
15: Ignition Output Signal
missing or defective ignition output signal
16: Fuel Injector System
defective circuit or unplugged / defective fuel injector
17: VSS (Vehicle Speed Sensor)
19: Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20: Electrical Load Detector
21: VTEC Solenoid Valve
22: VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
23: KS (Knock Sensor)
30: Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
31: Automatic Transmission Signal "B"
41: Primary Oxygen Sensor - Heater
check the heater for the proper voltage signal.
43: Fuel Supply System
check the fuel pressure, fuel pressure regulator. check the oxygen sensor. also, check for vacuum leaks.
45: System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48: LAF Sensor (Lean Air Fuel)
54: CKF Sensor (Crankshaft Speed Fluctuation)
58: TDC Sensor 2 (Top Dead Center)
61: Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63: Oxygen Sensor, Heated - Sensor 2 (Secondary)
65: Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67: Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
70: Automatic Transmission
malfunction with the automatic transmission controls
71: Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72: Cylinder 2 Misfire or a Random Misfire
73: Cylinder 3 Misfire or a Random Misfire
74: Cylinder 4 Misfire or a Random Misfire
75: Cylinder 5 Misfire or a Random Misfire
76: Cylinder 6 Misfire or a Random Misfire
80: Exhaust Gas Recirculation
insufficient flow detected
86: ECT Sensor (Engine Coolant Temperature)
circuit range / performance problem
90: Evaporative Emission Control System
leak detected in the fuel tank area
91: Fuel Tank Pressure Sensor
low input
92: Evaporative Emission Control System
insufficient purge flow
Old Sep 24, 2009 | 03:17 AM
The problem is almost never the ECU computer itself.
Check that all the sensors are plugged in securely. Check the ground wires on the thermostat housing.
The MAP sensor is mounted on the firewall and connected to the intake by a hose. If the hose is bad or disconnected you will get a code 5.
Whenever you have more than one code, reset the ECU and see which code reoccurs first.
Old Sep 24, 2009 | 03:43 PM
gwl's Avatar
gwl
Try to use original O2 sensors, for some reason Honda engine are temperamental with aftermarket sensors.
miguel11691
Nov 15, 2015 08:11 PM
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
Benny Sim
Jul 19, 2005 07:43 PM
