check engine light - coil
Old May 25, 2009 | 04:34 PM
waterbuffalo's Avatar
Default check engine light - coil
Hey guys, I'm newhere, figured you guys would know best...
I have a 2000 Civic DX, the check engine light came on a while ago, and after the car was warmed up, it'd idle rough. Then, not long after, the car would die when I stopped. It would start up again fine, but then die at the next stop. And the check engine light would start flashing. we got the code ran, and it was a misfire in cyl 1. A friend of a friend hooked up these lights between the plug and wire to check the spark and said I was getting a really weak spark. I had already replaced the plugs, wires, cap, and rotor, so we assumed the coil must be bad. I replaced that, and now the check engine light starts flashing before we even put it into gear when we start it. Any ideas? thanks.
Old May 25, 2009 | 04:41 PM
Use an engine stethoscope to listen for whether the #1 fuel injector clicks when the engine is idling. If so, swap the #1 and #2 injector to see if the misfire code follows the original #1 injector.
If injector #1 is fine, compression test the cylinders.
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
bplease
Jul 8, 2007 09:07 AM
Benny Sim
Jul 19, 2005 07:43 PM
