check engine light help
Old Dec 23, 2007 | 08:42 PM
darknightmr2's Avatar
Default check engine light help
k fellas, here's the problem. my friend has a D15vtec swap in his 93cx hatch. all the wires are ran correctly for vtec and everything. he's running a P28 as well.
here's where it gets interesting. when the car is on, his check engine light is constantly on. so, we ran diagnostic on it, and the light just stays on, meaning no codes. idk what that means then? its not showing any codes at all. we've reset the ecu, and still nothing, just a constant check engine light.
any clues or ideas?
Old Dec 23, 2007 | 08:47 PM
~Devin~'s Avatar
Default RE: check engine light help
i've heard that some manufacturers set it to where the light comes on every so many miles for maintenance and a mechanic has to do something to turn it off, but i dont know if thats true and if it is that could be the problem
Old Dec 23, 2007 | 09:02 PM
This unusual problem suggests either a faulty ECU or a faulty wire running between the ECU and either the CEL or the service check connector (see pictures).
Old Dec 25, 2007 | 03:29 PM
wow! thanks for the diagram and the quick replies fellas! we'll get this figured out for sure.
Old Dec 25, 2007 | 07:20 PM
MissCivic's Avatar
ORIGINAL: ~Devin~
Some manufactures do that but I always thought it was just in much newer and more expensive cars.
I had always heard that a solid CEL meant faulty ECU
Is the car running ok. I mean its not in like a safety mode or anything is it.
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
fastncrazy1
Jan 4, 2010 05:55 PM
Benny Sim
Jul 19, 2005 07:43 PM
