Check engine light went away after timing belt replacement?
Old May 12, 2010 | 12:06 PM
MasterJT's Avatar
Default Check engine light went away after timing belt replacement?
I took my car in for a timing belt replacement since its 11 years old and never had it done. But it only has 79800 miles on it. So the check engine light came on about a month ago. I took it to the shop and asked them what it was and they said it was the catalytic converter. I dont have the money to do that along with the timing belt so I just said to do that. When I got the car back the check engine light was gone. Why would it just disappear after a timing belt replacement? I know the catalytic converter still needs to be replaced cause I can hear the rattling. Im just wondering why the CEL is gone. Did they turn it off?
Old May 12, 2010 | 12:12 PM
croninc's Avatar
They might have just reset it, what year civic do you have?
Old May 12, 2010 | 12:15 PM
MasterJT's Avatar
Its actually a 99 prelude. But why would they just reset it? If I hadnt asked them what the problem was and they just reset it I wouldnt think anything was wrong.
Old May 12, 2010 | 12:17 PM
DaOne's Avatar
like croninc said it might have just been reset, it will probably come back after driving it for a few miles..
Old May 12, 2010 | 11:43 PM
MasterJT's Avatar
alright thanks for the replies. I drove it about 15 miles and nothings come up. i guess ill drive till it gives me problems.
Old May 15, 2010 | 04:04 PM
SilverSedan's Avatar
I have a dead cat (aka catalytic converter) on my car, its been like that for a while. the CEL is on, unless I disconnect the battery. It will stay off for a day (2 at most) before coming on again. However I have no driveability issues. Just so you know
Old May 15, 2010 | 05:45 PM
You reset the ECU [clear CEL's] when you unplug battery, so they just reset it. If there is a problem it will come back.
moonslice
May 5, 2011 03:41 AM
crashbang
Jun 23, 2009 02:33 PM
Davidov
Jun 14, 2007 10:28 AM
yairsaenz83
Feb 22, 2007 07:41 PM
grncivicvtec
Mar 22, 2005 01:55 PM
